John Rofrano
March 17, 2013 at 1:51 am[Mike Chang] “I thought that what ever you have DVDA Bitrate set to, that’s what would be rendered (regardless of if the format fit DVDA specs or not)”
No, that bit rate will only be used if you do not render a compliant file and it needs re-rendering. Otherwise DVD Architect will use whatever you give it as long as it’s compliant.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
John Rofrano
March 17, 2013 at 9:52 am
