Phil Peacock
October 20, 2013 at 7:46 amOh, and one other thing. I think you are actually getting a bit too complicated with the effects ! I noticed you have rather a few (read several) vfx in the chain, many of which were not activated (I’d say you have tried a couple of strategies and when they didn’t work . . . . . . Not really an issue but I can see your line of thinking and methinks you are, as I said above, making it more complicated than it really is. The answer is there somewhere and it will be so simple when you find it. Bah!!!
Fien Leysen
February 19, 2014 at 6:39 pmI know you weren’t expecting this (I certainly wasn’t), and by now you might no longer be interested, but I finally figured it out!!
It was way simpler than I ever imagined and it probably comes close to several suggestions you made.Apparently, I did the first project without overlaying solids.
All I had to do was resize each clip using the event pan/crop button (not the resize option for the entire track). Then add an effect to the entire track; brightness/contrast and guassian/blur. This ensures that the blurring takes place outside of the frame. Make both effects happen over the course of only 3 or 4 keyframes, after which the image disappears.Yes. It was that simple. No feathering, no solids, no nothing complex. I can’t believe it. Hours, days, and months of work and crashing projects. Quite educational. I’m sorry for dragging you along 🙂 Thanks for all your help!
https://reels.creativecow.net/film/final-intro
Phil Peacock
February 20, 2014 at 11:46 amWow and wow. First wow because, after being away overseas for four months I return home, reinstate the computer back-up files on the computer that my wife has managed to crash in my absence and on the second day of it being on – I get your response!!!! I am delighted.
And the second wow covers everything else; that you persevered, that you found a very elegant solution, and that you thought to share that solution. Haha, I am even more delighted!
And well done. As I said, very elegant and if anyone else reads this, I think a solution that might become popular with a lot of ‘creators’ out there.
Thanks again Fien and good luck with your future video projects.
