Activity › Forums › Blackmagic Design › Bob Z could you help one more time
  • Reggie Spires
    February 6, 2008 at 12:37 am
    Well the good news is I only paid 150.00 for the decklink card and then there is that whole stupid “more than two gig of ram” thing. So I might just sell this and spring for the card you recommend
  • Del Chapple
    February 6, 2008 at 3:24 pm
    fyi, not sure if blackmagic ever fixed this problem they havent with the multibridge yet. the D to A component analog side works as expected but the A to D side still has problems, you’ll never get a proper setup on the output.
    del
    you cant hear my inner voice scream… can you..?
  • Chris Borjis
    February 8, 2008 at 12:15 am
    I had the issue with my multibride extreme until I checked the “use betacam levels” option in the decklink applet.
  • Del Chapple
    February 8, 2008 at 12:33 am
    I wish it was that easy, i know beta and smpte level. I tested the yrb A to d straight into a BVW75, D-Beta and the Multibridge will not send proper signal out the yrb A to D in ntsc, but pal is fine. I’ve tried a few MB’s and all the software versions and still no worky.. Maybe they fixed it on the extreme??
    d
  • Chris Borjis
    February 9, 2008 at 12:02 am
    do you mean capturing via analog component on your multibridge is a problem?
    what exactly do you mean by that? for example if you send bars to the component inputs, and you have a vectorscope up are you saying it won’t properly align to a calibrated signal?
    I do have that problem BUT only on the Multibridge Extreme COMPOSITE output and there is nothing I can do to fix it.
    Is that the problem you have but on the component inputs of the multibridge pro?
    Black Magic Design definitely needs to fix this if its a problem.
Page 2 of 2
