Activity › Forums › Blackmagic Design › BMD Cinema Camera!
Morten
April 16, 2012 at 8:54 pmUnfortunately the sensor is smaller than four-thirds, rendering most Canon lenses unusable…
– No Parking Production –
2 x Finalcut Studio3, 2 x Prod. bundle CS5.5, 2 x MacPro, 2 x ioHD, Ethernet File Server w. X-Raid…. and FCPX on trial
Margus Voll
April 16, 2012 at 9:44 pmstill at that price point this is just amazing!
one still needs to have nice glass and nice lighting to make most of it as with any other camera.
lovely product!
Margus
Shane Betts
April 16, 2012 at 10:16 pmThey either need to offer an NEX or 4/3 mount or a bigger sensor. That aside, looks amazing.
Cheers
Bettsy -
Steve Connor
April 16, 2012 at 10:16 pmWell done BMD, thanks for stirring it up.
Steve Connor
“FCPX Professional”
Adrenalin Television -
Hampus Lager
April 16, 2012 at 10:29 pmWhy do they to? Most people use Canon or Nikon mount lenses and there’ll be plenty of adapter for this. Bigger sensor? get a used 5D mkII 😛
Hal Lovemelt
April 16, 2012 at 10:32 pmwhen you say that do you mean content aquisition, or for live… Im very curious if the HD-SDI feed is capable of live video… any idea?
Nigel Thompson
April 16, 2012 at 10:38 pmMy only problem with the cam from what im seeing is the very tiny sensor, so a wide shot wont be wide at all. Even if you find an 8mm lens or something it’ll equate to a 20mm on this sensor… other than that it looks fantastic
High End, Production & Post Production
in the Caribbean
http://www.bistt.com -
Will Salley
April 16, 2012 at 10:49 pmLooks like a great concept. Unfortunately, it has a very small effective sensor area (roughly 1280×720)
https://www.blackmagic-design.com/products/blackmagiccinemacamera/techspecs/
So that’s where the execution falls short. As mentioned in an earlier post, maybe it’s a precursor to a larger sensor model.
Mac Pro 2×2.8 Quadcore – 10.6.8 – 22 GB RAM – nvidia8800GT – SATA internal & external storage – Blackmagic Multibridge Pro – Open GL 1.5.10 – Wacom Intous2 tablet – AJA io
SONY XDCAM EX3 – Letus Elite – FC7.0.2 – CS4 Prod Prem. -
Shane Betts
April 16, 2012 at 10:51 pmThey need a bigger sensor or a mount with a shorter flange distance because smaller sensor means any given lens performs more like a telephoto. In other words, no wide angles!
I have no problem with the small sensor per se, god knows we could all use more shots actually in focus, but a lens mount designed for such small sensor sizes would allow us to access wide angles. And an NEX or 3/4 mount still lets you use EF and Nikon mount lenses with common, cheap adaptors.
That’s why.:-)
Cheers
Bettsy -
Shane Betts
April 16, 2012 at 10:53 pmYes Will, they do make several references to the camera “family”, thus far one camera and a handle. Looks like more to follow, which sounds like Grant’s MO.
Cheers
Bettsy
