Activity › Forums › Creative Community Conversations › BMD Camera Update
  • Oliver Peters
    July 18, 2020 at 8:56 pm
    I played around with a few of the 12K clips today. Resolve doesn’t see them at all. I suppose you have to go with the beta instead of the current version for now. I did install the beta of their BRAW support, so Premiere does see the files and the RAW controls do work. However, brutally slow. This was on a mid-tier iMac Pro and Promise RAID. So unusable at the moment unless you have a very beefy Mac Pro or PC. Maybe the Resolve beta is better.
    OTOH – the BMD RAW Player app does play these files nicely even on my older MBP and a USB 3 drive. So that would lead me to believe performance will improve once it’s all tweaked.
    – Oliver
  • Bill Davis
    July 19, 2020 at 12:20 am
    [Michael Gissing] “In relation to FCPX, the significant issue with this camera is also the performance of BRAW. I hope Apple are looking at how BRAW is developing and the petty (see what I did there) RAW wars will not continue. I want to see BRAW and ProResRAW available in FCPX and Resolve”
    Was on a Zoomchat meeting this morning watching Steve Bayes (former Product Manager for FCP X) and while he was CRYSTAL CLEAR that since retiring a few years back he knows NOTHING about any plans or status for anything like BMRaw coming to FCP X — he did GENERALLY note that one “factor” in any codec coming to a platform is the resources it takes to support an outside codec once it becomes an official part of different companies offerings. It’s apparently not a trivial thing. He mentioned that’s why Apple leaves, for example, Canon MXF Codecs as something for Canon to develop and maintain.
    The support burden requirements then fall to Canon to cover.
    Same with RED stuff. (tho I understand that’s partially because RED didn’t want to disclose some of their codec secrets as well, so there desire to keep things “in house” was even stronger.)
    Imagine the extra support load Apple would face in training, phone support and general troubleshooting if they folded BRAW into the official Apple portfolio of supported products?
    Just food for thought.
    Creator of XinTwo – http://www.xintwo.com
    The shortest path to FCP X mastery.
  • Steve Connor
    July 19, 2020 at 11:21 am
    [Oliver Peters] “So unusable at the moment unless you have a very beefy Mac Pro or PC. Maybe the Resolve beta is better.”
    I get full resolution, full frame rate on my iMac with 8GB Graphics card using the Beta and a USBc SSD drive, even after adding a few nodes of correction so it’s probably only unsuable if you don’t run the beta
  • Oliver Peters
    July 19, 2020 at 2:29 pm
    [Steve Connor] “so it’s probably only unsuable if you don’t run the beta”
    Yes, that sounds correct. The clips did play well on my older MBP using the Blackmagic RAW Player app, which is likely not tapping into the full quality de-Bayer resolution. The current release version of Resolve (not the beta) won’t recognize the clips. Premiere was super-slow, even with the beta RAW support software installed. However, I would imagine it will take an Adobe update before that’s better optimized.
    – Oliver
    Oliver Peters – oliverpeters.com
  • Oliver Peters
    July 19, 2020 at 2:33 pm
    [Bill Davis] “it takes to support an outside codec once it becomes an official part of different companies offerings. It’s apparently not a trivial thing. He mentioned that’s why Apple leaves, for example, Canon MXF Codecs as something for Canon to develop and maintain.”
    All true, yet somehow Adobe, Avid, and others manage to accomplish this even without the advantage of having control of the supporting video framework within the OS itself.
    – Oliver
  • Michael Gissing
    July 20, 2020 at 12:00 pm
    [Joe Marler] “Why can’t BMD write a similar plugin to enable BRAW support in FCPX like RED and Canon did for their raw formats?”
    They have published their SDK from day one and so Pr can play BRAW. It’s not BM’s job to write a plugin for FCPX. The SDK is published and free. BM are not in the business of writing plugins for lazy NLE software companies. Either Apple do the job or it’s up to any third party who make a buck out of Apples laziness to develop their software properly. Do you expect BM to also write a plugin so Apple can export an AAF to DAWs?
  • Michael Gissing
    July 20, 2020 at 12:02 pm
    Oliver, so far the beta Mac version of Resolve is designed to play the BRAW 2.0 files from the new camera.
  • Michael Gissing
    July 20, 2020 at 12:05 pm
    [Bill Davis] “one “factor” in any codec coming to a platform is the resources it takes to support an outside codec once it becomes an official part of different companies offerings. It’s apparently not a trivial thing. He mentioned that’s why Apple leaves, for example, Canon MXF Codecs as something for Canon to develop and maintain. ”
    Yes Apple is unlike other NLEs in that it leaves codec and interchange support up to others. It’s lazy and indicative of an attitude that makes people like me unimpressed. If Resolve or Pr had the same attitude, collaborative workflows would be a nightmare with FCPX. Lucky for Apple others have picked up and made money from their slack.
  • Michael Gissing
    July 20, 2020 at 12:08 pm
    [Oliver Peters]”Overall, forget about the RAW. What’s really interesting is that BMD has deviated from the “off-the-shelf” Bayer-pattern sensor design.”
    BRAW is actually an integral part of the equation. It is the development of this sensor that has been part of the BRAW story. The two are inseparable which is why this new camera only records BRAW. BM see the codec as making such res possible. Imagine a 12k DNx or ProRes? It’s clear to me that BRAW is the key to this camera and the new sensor.
  • Michael Gissing
    July 20, 2020 at 12:13 pm
    [Steve Connor] “Although I’d read the 12K doesn’t record Prores internally?”
    Since being able to record BRAW in my BMpocket4k, I have not once considered using the onboard ProRes. There is a very good reason BRAW is the only codec on the 12k. It’s actually the only codec that makes sense. ProRes can’t record above 8k and the file size for a 10 bit file is larger and far less useful in post. If it was on the 12k I have just ordered, I am sure I would never use it. No point in paying Apple a license for a codec that no longer has any need in acquisition.
Page 3 of 4
