Activity › Forums › Apple Final Cut Pro Legacy › Blu Ray Authoring in Studio Pro
Walter Biscardi replied 17 years, 6 months ago 12 Members · 18 Replies
Rafael Amador
February 15, 2009 at 3:15 amAs Chris points the easier and cheapest way is Toast, but, of course, don’t do the transcoding with him. You need to compress your assets in other application: Compressor, Episode,..
rafael -
John Higgs
February 15, 2009 at 9:00 pmThanks Guys,
I have been using Toast 9 + HD Plugin, but the authoring is very Mickey Mouse.I burn on standard DVD disc with the Mac Pro burner, and play on any Blu Ray player profile 1.1 or higher , i do shoot HD-CAM and very pleased with the quality i get on disc. I have produced HD-DVD disc in Studio Pro, like the set up, any way i’ll keep my fingers crossed and hope one day Apple will surprise me!!!!!!.
Regards,
John Higgs. -
George Sloan
March 6, 2009 at 3:08 amCan I export projects from Final Cut Pro using compressor to
Toast 10 and burn HD Blu Ray using my Mac Pro 2.66 MHZ. ????Admittedly Confused
Walter Biscardi
March 6, 2009 at 12:28 pm[george sloan] “Can I export projects from Final Cut Pro using compressor to
Toast 10 and burn HD Blu Ray using my Mac Pro 2.66 MHZ. ???? “With a BluRay burner yes.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
Steve Mathews
March 6, 2009 at 3:35 pmWhat workflow are you using? Is the process complicated for transferring from Apple FCP onto the PC for writing to Blu Ray?
Walter Biscardi
March 6, 2009 at 3:48 pm[Steve Mathews] “What workflow are you using? Is the process complicated for transferring from Apple FCP onto the PC for writing to Blu Ray?”
No, an MPEG-2 is an MPEG-2 no matter what platform you take it to.
Steve Mathews
March 6, 2009 at 4:34 pmOk, so you output to an MPEG2 file, then transfer it to the PC and DoStudio? Obviously a huge file so are you transferring over fibre channel?
Walter Biscardi
March 6, 2009 at 4:41 pm[Steve Mathews] “Ok, so you output to an MPEG2 file, then transfer it to the PC and DoStudio? Obviously a huge file so are you transferring over fibre channel? “
USB Stick, USB Drive, Firewire Drive, whatever is handy.
