Activity › Forums › Apple Final Cut Pro › Better to conform 60FPS to 24fps?
Oliver Peters
February 8, 2013 at 12:17 pmTry converting to ProRes and see if that changes things. It might be a problem because of the LongGOP structure of the H264 file.
Oliver
Orlando, FL
http://www.oliverpeters.com -
Beachwood Productions
February 8, 2013 at 3:08 pmI’ll give it a try. Thanks for the help Oliver. 🙂
Peter Wilcox
Beachwood Productions -
February 10, 2013 at 11:45 pmBetter yet I found that my new GH3 records native slow motion. 🙂
Peter Wilcox
Matias Canelson
July 17, 2013 at 1:58 amWell, I hit a wall today… 59,94fps media imported and conformed inside a 23,98fps timeline doesn´t show up in DaVinci Resolve (9.1.5 and FCP 10.0.8).
We don´t use Resolve in our company, we use Scratch, but I was running some test today and I found this and looks like it´s a common problem. Which I wouldn´t have if I conformed the files using CinemaTools before editing. Finally I exported an Apple ProRes 422 (HQ) file to Scratch to grade (media was shot with a 5D MarkIII).
Does any of you know a good (free) alternative to just change the header of the quicktime file?
PS:After a little research I found this blog with a complete (and very technical) guide to roundtrip from FCPx to DaVinci
Part 1: https://wolfcrow.com/blog/how-to-round-trip-from-final-cut-pro-x-to-davinci-resolve-part-one-fcp-x-to-resolve/
Part 2: https://wolfcrow.com/blog/how-to-round-trip-from-final-cut-pro-x-to-davinci-resolve-part-two-resolve-to-fcp-x/
Part 3: https://wolfcrow.com/blog/how-to-round-trip-from-final-cut-pro-x-to-davinci-resolve-part-three-dealing-with-changes/
Part 4: https://wolfcrow.com/blog/how-to-round-trip-from-final-cut-pro-x-to-davinci-resolve-part-four-round-tripping/—
MatiasCanelson
http://www.canelson.com.ar -
Jeremy Garchow
July 17, 2013 at 2:18 am•I don’t know of any free ones. QTEdit will do this, but its not free.
•You could bake the clips in before Resolve.
•You could put the original clips in a different time base project and grade and conform those separate, just leave a gap clip for timing in the master. When you get the returns, simply add back the clips and adjust their timing back to where they were in the offline.
Joe Shapiro
July 15, 2014 at 11:56 pmJust found a free conform tool:
https://arvidtp.net/sw/lossless_frame_rate_converter.php
Joe Shapiro
Director / Producer / Editor
206-420-6411imdb.com/name/nm1497731/
twitter.com/JoeSh
