Ron Muse
February 26, 2013 at 5:14 pmI am assuming, that you are referring to the video rendering only, and not the entire project when you say 8.5 bit rate. Am I correct in this assumption?
Tanja Tabucija
October 12, 2013 at 12:46 amhy, mike and others… i would be grateful if someone can explain to me how and what to do… i have wedding video and wedding pictures, also i have made intro for dvd and menu for dvd (image and menu format for photodex proshow program). i have made a beautiful slideshow with photodex proshow and now i don’t know what to do… when i export it to hd it is good but i need to make a dvd disc, when i do that the quality is terrible… i need the best resolution for 1:14 hours and 11 sec. which is duration of my mp4 movie (slideshow) to record it on normal dvd player, not blu-ray… so which program i can use, because it seems that photodex proshow is not good for making dvd… or i’m doing something whrong. the problem is that i have to export it in mp4 and then put it in again because i have created my menu also and it has so many options that program, just it is not good with rendering or converting… i don’t know how to make best quality and resolution, because you cannot export .psh file of project in photodex… i need european (croatia) format in widescreen, i think PAL is a right choice, but how to burn it on dvd, it becomes large about 8 gb and i can burn it on dual layer if the regular dvd player can read that dvd-s… but i don’t know anymore, i have tried so many things and quality is low… not so good like on comp or hdmi output on my widescreen tv. in other programs i don’t have so many effects and possibility to make dvd menu with intro like in this one… but i have to put out averithing somehow to be able to burn it on dvd for regular dvd players… please help me and sorry for my language i’m from croatia and i can’t find explanation for my question because i’m using photodex proshow! thanks in adwance
