Best output format when rendering a project to be burned to DVD?
John Rofrano replied 10 years, 9 months ago 5 Members · 14 Replies
Seth Kopchu
December 8, 2015 at 3:45 amI have John’s answer, which I appreciate. Two separate files to be authored professionally.
My next question then, what MPEG2 option would be best to render both the audio and video into one file for playback, instead of the already mentioned two separate files? I understand that this is a more simpler, not-as-optimal way of burning a project to DVD, but think of it as a Plan B. Thanks guys.
John Rofrano
December 8, 2015 at 12:57 pm[Seth Kopchu] “My next question then, what MPEG2 option would be best to render both the audio and video into one file for playback, instead of the already mentioned two separate files? I understand that this is a more simpler, not-as-optimal way of burning a project to DVD, but think of it as a Plan B.”
Open the MPEG2 template, select the Audio tab and check “Include Audio”. Then save the template under a new name and use it.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Seth Kopchu
December 9, 2015 at 9:58 pmJohn, I went ahead and made my DVD per your suggestions. Thank you again, and as always. I now have some questions regarding optimizing my disc in DVD Architect Pro 6.0 right here.
John Rofrano
December 10, 2015 at 3:32 pm
