Activity › Forums › Apple Final Cut Pro Legacy › Best codec for MBP edit – without AJA IO/LD?
Brett Nelson replied 19 years, 6 months ago 4 Members · 13 Replies
Bret Williams
February 16, 2007 at 9:45 pmYeah, from my experience Atl is a sony town for sure. Walter? 🙂
Jeremy Garchow
February 17, 2007 at 1:36 amAre you being facetious because Walter captures Varicam material for Good Eats in Atlanta? Look at the formats you mention and then restate what you are trying to say as I’m confused.
Jeremy
Brett Nelson
February 19, 2007 at 9:52 pmHello,
Thanks for the very helpful thread! I want to see if I’m getting this straight… How well will it work if I capture DVCPro50 using only the onboard firewire ports? Would I still be able to capture using a FW400 drive?I’m currently working on two projects, one is a 60-second spot, the other is a 10-minute promo cut from 10 hours of footage.
Brett Nelson
MBP 2.16
1 GB RAM
FCS 5.1.2
