Marc Istook
October 15, 2007 at 3:40 pmThanks for the response…
I didn’t use Raylight because I don’t have Raylight… And my typical workflow with this camera will involve FCP. I’m a loyal Vegas user, but my company has a new FCP setup they’ll be using mostly in the future.
I transfered the footage from 24pN to MiniDV, inserting a 2:3 pulldown — 24p regular.
Smart resampling was selected. I didn’t intend to keep it progressive by switching to a 24p timeline — just wanted the 24p look on a 29.97 timeline, which should not have been a problem using 2:3 pulldown 24p footage.
I don’t suspect inverted fields, if only because I’ve checked each step of the process, and lower field first was used every step of the way — though I’ll double-check.
The resampling could be the culprit — I think Vegas having to deal with the widescreen par might’ve caused some problems somewhere. I’ll check the resampling issue and see if that’s the problem.
Again, thanks for your help.
– Marc
Xdirect
October 18, 2007 at 4:18 pmDo you have nested projects in your workflow? If so, try rendering each project then doing a replace on the .veg files in your final project. I had a bad interlacing problem that resulted, inexplicably, from vegas and nested projects. Hope this helps.
