Activity › Forums › Adobe After Effects › Background goes black when made 3D
Mark Chow
February 22, 2019 at 8:02 amOMG thank you so much…….glad to know that I am not the only dumb
Gerrit Schulze
March 26, 2019 at 5:26 pmHi Tristan,
like John Stanowski said (many thanks for that John!) your 3d view should be set to ‘Active Camera’.
In your screenshot right in the middle below the viewer you see ‘Left’ in the camera view drop-down. Set this to ‘Active Camera’ to wipe out that misterious black ????.
Regards,
Gerrit -
Davi Herold
October 28, 2019 at 3:40 pmFive years later and you’re still helping people with your comment!
Cheers!
Deborah White
November 1, 2019 at 2:24 amHi, I have the same problem. I am using keylight on videos and when I turn them to 3D layers with Cinema 4D renderer the masked areas turn black. I’ve tried all the suggestions above and cannot solve the problem. I’ve tried pre-comps, altering the light and the camera. Please help!
Andrey Gavrilkin
November 29, 2019 at 10:13 amStill relevant in 2019-20. thank you. I though its a bug, restarted Ae couple of times already before finding this!
Max Haller
December 2, 2019 at 9:28 pmIve had issues with the cinema 4d renderer doing that to PSD files, try clicking on where it says Cinema 4D and changing it to the Classic 3D renderer. That fixed the PSD problems for me, might work for your problem.
Deborah White
December 2, 2019 at 11:01 pmThanks Max.
I wanted to use the cinema 4D renderer but I’ve had to change my project to use classic 3D. -
Diana Krum
June 3, 2020 at 5:04 pmHello,
Had to set up an account only to continue the discussion.
I was having the same problem and altering the lightning, 3D mode and everything else didn’t help. What did help in the end was so simple I kind of feel silly.Toggle the Draft 3D icon on and off:
In my case when using the 3D in “draft” mode some files (e.g. pngs) lost their transparency.
Lance Clayton
September 3, 2020 at 1:40 amYep – sent to ‘FRONT’ .
John – the community owes you for this post.
