Activity Forums Adobe Premiere Pro AVCHD video doesn’t sound sync with video
  • AVCHD video doesn’t sound sync with video
    Posted by Suzin Daly on January 19, 2025 at 7:19 pm
    I haven’t used my Panasonic 150…for yrs. I dropped the video onto PP 2025 for the first time, the video and sound were slightly out of sync. I fixed it by unlinking, and relinking once the sound was synced. I did a test and dropped the video into an old version PP C6 and snc was perfect. Out of curiosity, does anyone know what settings I can use to avoid this? (Please don’t say get a new camera.) I’m not doing a whole lot. Little I do, with DSLR. If there is a work around be nice to know.
    Devrim Akteke replied 1 year, 6 months ago 4 Members · 11 Replies
  • 11 Replies
  • Eric Santiago
    January 20, 2025 at 4:01 pm
    Framerates?
    Not sure what your specs are and what your sequence settings set at.
    usually old school issues was the drop frame part.
  • Rob van Wely
    January 29, 2025 at 11:56 am
    When importing a MTS video file into Adobe Premiere Pro 2024, the video track and audio track are not synchronized. I can see that the audio track is empty before the end (See attached jpg). When unlinking the video and audio tracks, cutting the audio track from the time there’s no more audio, deleting the empty part, and adjusting the speed/duration of the audio track to the duration of the video track, the problem seems to be solved. But if I have to do that for every imported MTS file in a project, that’s really boring, takes a lot of time. Is there not a way to fix this problem in preferences, or wherever in Premiere Pro?
    This problem does not occur when importing MOV files, shot with my more recent camera. But I still have a lot of MTS video files I want to use for my new projects.
    Can you please help?
    Thanks in advance, Rob
  • Devrim Akteke
    January 29, 2025 at 12:18 pm
    I think the problem is that Premiere Pro doesn’t support AC3 audio codec anymore due to high licensing fees. And as MTS recording cameras aren’t very recent, there will be no support for it. One way to fix this is, not a short one, sorry, using the Media Encoder to convert these MTS files to mov before importing them into Premiere Pro.
  • Eric Santiago
    January 29, 2025 at 6:48 pm
    And if not AME, there are utility apps that convert MTS to .mov or whatever is supported in your system.
  • Suzin Daly
    January 30, 2025 at 8:37 pm
    I got that the file is no longer supported. There are work arounds. For what I’m doing these days, I still have PPC6…
  • Rob van Wely
    January 31, 2025 at 2:19 am
    Hello Devrim
    thanks for your advice. I’ll try what you suggested.
    Best regards,
    Rob van Wely
  • Rob van Wely
    January 31, 2025 at 3:10 pm
    Hello again.
    I tried to convert a rather large MTS file (3,99 Gb) in the Media Converter. That took a long time before the converter announced that it failed. As I chose to save the converted files in the same folder as the original file, I discovered a -even larger- MOV file (23,5 Gb) that has even bigger audio problems (many dropouts) and lasts only 4 minutes and 5 seconds…
    So now just found another way to solve this problem; in Cyberlink Power Director (software I used before switching to Premiere Pro a few years ago) I uploaded the same MTS file, then saved only the sound as a WAV file. That went very quickly. Then imported the same MTS file into Premiere Pro, and the just produced WAV file as well. Unlinked le video and audio track of the MTS file, deleted the audio track. Then copied the WAV file under the MTS video track, and that works perfectly.
  • Suzin Daly
    January 31, 2025 at 3:57 pm
    Thanks for sharing
  • Devrim Akteke
    January 31, 2025 at 4:55 pm
    That’s great. Exporting only audio is an excellent method. 🙏
  • Rob van Wely
    February 27, 2025 at 1:17 am
    Hello again.
    Following the method I described (using Cyberlink PowerDirector to create wav files) that’s working fine being very fast doing so, I keep on thinking that
    if the problem with Premiere Pro is that it doesn’t support AC3 audio codec anymore due to high licensing fees how come that a cheap software as Cyberlink PowerDirector is able to do VERY fast what the Media Encoder takes AGES to do, if it doesn’t stop after hours and a message pops up saying it failed.
