Activity › Forums › Apple Final Cut Pro › AVCHD Import
  • Tom Wolsky
    December 26, 2012 at 3:55 pm
    1) Kingston are usually reliable. The important point is to make sure it is a class 8 or better card.
    2) Software like Card Rescue can be helpful.
    All the best,
    Tom
    “Final Cut Pro X for iMovie and Final Cut Express Users” from Focal Press
    “Complete Training for FCPX” from Class on Demand
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
  • Fabrizio D’agnano
    December 26, 2012 at 5:30 pm
    I am glad it worked. Before going for a replacement card I’d try to see if it was an hardware problem with it or just some corrupted file. You already have the .dmg on a drive, so you have a copy of the card content for trying a further recovery . I think you can initialize the card inside the camcorder, shoot a few clips, and see how it works. You can do it a few times, and it everything works fine, you can blame it on a corrupted file or such, saving the card for future use. I can’t help you about the software for converting the mts files to mov at full quality. At the time I had the same problem I downloaded a couple of cheap ones named “AVCHD Converter” and “SmartConverter”, both from the Apple Store, but I remember on of the two was not offering a full quality conversion. I have them at my office, I’ll be there tomorrow and I’ll check.
    Regards
    Fabrizio D’Agnano
    Rome, Italy
  • Scott Logan
    December 26, 2012 at 5:59 pm
    Great idea to initialize and test the card before chucking it. I’ll do that.
    Thanks so much for your time and coaching, Fabrizio. Happy New Year!
  • Scott Logan
    December 26, 2012 at 6:01 pm
    Thanks so much for your time and coaching, Tom. Much appreciated.
    Happy New Year!
  • Fabrizio D’agnano
    December 26, 2012 at 6:36 pm
    You’re welcome. I was saved by people sharing knowledge and experience in this great forum so many times that I am glad I can be of some help for somebody once in a while myself 🙂
    Happy New Year to you!
    Fabrizio D’Agnano
    Rome, Italy
  • Scott Logan
    December 26, 2012 at 7:52 pm
    Paying it forward is a beautiful thing, indeed, Fabrizio.
    Just wanted you to know that I did reformat the SD card that appeared to have failed and it seems OK now. You saved me a few bucks there. Nice! Thanks again!
  • Don Smith
    December 29, 2012 at 12:19 pm
    Scott, just covering a base here, have you possibly renamed any part of the camera card that won’t import? FCPX is looking for a particular file structure. Compare folder names with a card that worked.
    NewsVideo.com
  • Scott Logan
    December 29, 2012 at 3:40 pm
    Good thought, Don.
    No, I never changed anything within the file structure of the suspect card. Still, I would compare the suspect card with a working card if I could, but I have since reformatted the suspect card, which is working normally again. All that remains from the copy of the suspect card I did have are the .MTS files.
    By the way, Don— or anyone— can you suggest a tool I can use to convert these .MTS files (in a lossless way) so they become importable by FCPX?
    Thank you!
  • Don Smith
    December 29, 2012 at 3:44 pm
    I paid $36 for iSkysoft Video Converter for the Mac and have had good luck with MTS files. Are they lossless? I don’t know but visually indistinguishable from the original. I convert them to ProRes.
    You may not know but you want the original file structure because its those other files that will dictate which clips should be reassembled as one (spanning) so that you don’t have a clip ending in the middle of a word and you have to butt the next clip to it to get the full shot.
    https://www.iskysoft.com
    NewsVideo.com
  • Tom Wolsky
    December 29, 2012 at 3:55 pm
    ClipWrap simply rewraps to QuickTime without recompressing and converts the audio to uncompressed.
    All the best,
    Tom
Page 2 of 3
