Activity › Forums › Adobe Premiere Pro › Auto Shutdown PC after Encoding Done – Premiere Pro / Media Encoder
Luca Terzi replied 10 years, 4 months ago 8 Members · 15 Replies
Luca Terzi
October 16, 2015 at 12:04 pmI’ve just wrote something that takes into account the load of the CPU for the specific process.
When AME finishes the CPU of the process “Adobe QT32 Server” used by AME to encode drops to 0.000000, and that’s what I’m looking for.
This code is set to shutdown the pc if the that process reaches that condition, checking every 90s and in case it finds the process at 0.000000 it will wait other 90s to be sure that the encoding is really ended.@echo off
SET “SERVICE=Themes”
SET USAGE=”0.000000″
SET /A “INTERVAL=90”
SET prc=Adobe QT32 Server:LOOP
cls
For /F “tokens=2 delims=,” %%P in (‘typeperf “Process(%prc%)%% Processor time” -sc 1 ^| FINDSTR /rc:”[0-9]”‘) do (
IF %%P EQU %USAGE% (
echo Waiting 60s…
Ping -n %INTERVAL% Localhost >NUL
For /F “skip=1 tokens=2 delims=,” %%P in (‘typeperf “Process(%prc%)%% Processor time” -sc 1 ^| FINDSTR /RC:”[0-9]”‘) do (
echo Encoding DONE!
echo Closing Adobe Media Encoder…
taskkill /IM “Adobe Media Encoder.exe” >NUL
echo Now Shutdown…
shutdown /s /t 60
) ELSE (
echo Encoding in Progress!
GOTO :LOOPHope you will find it useful.
LT -
Oki Pienandoro
May 17, 2016 at 4:13 amCan you post the bat file?
I can’t get it to work (AME CC 2014)——————————————
Sorry for the english, not native speaker. -
Luca Terzi
May 17, 2016 at 7:27 amHi,
Indeed I completely changed everything time ago, but I forgot to post it here.. But this time I did it with PowerShell ISE.
Now it checks the total load of the CPU and it shuts down the computer if the load is lower than 20% (in this case).
If it detects that the CPU works under the 20% then it checks it again after 60 seconds (in this case), and in case it’s not loaded it shuts down AME and then the computer:# Set the policy otherwise it will not run
Set-ExecutionPolicy Bypass -Scope CurrentUser# Close the programs before to check the use of the CPU
Write-Host “Closing Skype..”
Get-Process -name Skype -erroraction silentlycontinue |
Stop-Process
Write-Host “..DONE”# Minutes to wait before checking the CPU’s load
$time = 60Start-Sleep -s $time
# Load reference percentage:
$ref = 20$cpu = Get-WmiObject -class Win32_Processor |select LoadPercentage
$load = $cpu.LoadPercentagewhile ($load -gt 0)
# Get the current load of the cpu
Write-Host “$load %”# If the cpu works under the reference number check if it’s really finished and in case shutdown the pc
if ($load -lt $ref) { Write-Host “Encoding Finished?”
# Get the current load of the cpu, again..
if ($load -lt $ref) { Write-Host “Encoding Finished!”
Write-Host “Closing Adobe Media Encoder…”
Get-Process -name ‘Adobe Media Encoder’ -erroraction silentlycontinue |
Stop-Process
Write-Host “..DONE!”
Start-Sleep -s 15
Write-Host “Now sleep..”
Stop-Computer
}else { Write-Host “Encoding in Progress!”
Clear-Host
Oki Pienandoro
May 17, 2016 at 9:11 amThis is the fastest reply i ever came across from an old thread !
Thank you.Couple of question,..
1. I try to run it on idle/working AME, and the script simply close again. Where did i do wrong ? I copy paste the script into PowerShell ISE, save it then run it.
2. Why there is a function to close Skype ?
3. Is it possible to check the upload status in published option jobs?
4. Can it be used/expand to sent email using SendEmail ?
https://caspian.dotconf.net/menu/Software/SendEmail/Also, i came across this command couple of hours ago(but i translate it into english), from German YouTube:
https://www.youtube.com/watch?v=NiZn8VN5YTEBasically the way it works is by checking whether the dummy files (sd.*) is created (we put a “fake” render at the end of job queue).
After the dummy file is created, it execute the shutdown command. So it’s not a guess work based on CPU load.
I also add a line to sent an email using the SendEmail app that i posted above (i wish it can sent just the URL), i use a workaround to sent an AMEEncodingLog.txt.txt files instead. Not pretty.It works wonderful, but this one has limitation to expand the script beyond this.
While your script i believe can be expanded to any program that heavily utilize CPU load, right ?@echo off
title AME Auto Shutdown:A
if exist sd.* goto TRUE
echo.
echo Date: %date%
echo Time: %time%
echo.
echo State: Renders.
echo.ping /n 2 localhost >nul
cls
goto :A
:TRUE
echo.
color 0c
echo Date: %date%
echo Time: %time%
echo.echo The PC has been shut down successfully on %date% at %time% ! >> log.txt
echo Status: RENDERING FINISHED!
echo.
echo PC will shut down in 60 seconds!
echo.shutdown /f /s /t 60
pause >nul
cls
Sorry for the english, not native speaker.Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Luca Terzi
May 17, 2016 at 9:26 amI did it with Windows 7 and I just tried it with Windows 10 and it works perfectly, how did you save the file? Mine has extension .ps1
There is a function to close skype because I wanted like this in my computer 🙂
Unfortunately I don’t know how to check the upload status.
For sending an email you have to implement this: https://technet.microsoft.com/en-us/library/hh849925.aspx
Last but not least, yes, it checks only the load of the CPU, not AME directly (but with an encoding program such as AME is very effective because the CPU usage drops to very few percentage points after the program finishes to encode a video).
