Activity › Forums › Compression Techniques › Audio Sync Problems using compressor
  • James Bayliss-smith
    September 4, 2009 at 6:50 am
    Here Goes:
    Settings
    Description: HD for Vimeo
    File Extension: mov
    Estimated file size: 2.15 GB/hour of source
    Audio Encoder
    AAC, Stereo (L R), 44.100 kHz
    Video Encoder
    Format: QT
    Width: 1280
    Height: 720
    Pixel aspect ratio: Square
    Crop: None
    Padding: None
    Frame rate: (100% of source)
    Frame Controls On:
    Retiming: (Fast) Nearest Frame
    Resize Filter: Linear Filter
    Deinterlace Filter: Better (Motion Adaptive)
    Adaptive Details: On
    Antialias: 0
    Detail Level: 0
    Field Output: Progressive
    Codec Type: H.264
    Multi-pass: On, frame reorder: On
    Pixel depth: 24
    Spatial quality: 75
    Min. Spatial quality: 25
    Key frame interval: 25
    Temporal quality: 50
    Min. temporal quality: 25
    Average data rate: 5.12 (Mbps)
    Workflow
    I captured HDV footage as ProRes 422 (Normal Quality) straight into Final Cut Pro.
    I am using Compressor version 3.0.5
    Why did you suggest I read the chapter on Frame controls? I understand that this is the most important part of compressor but did you have any particular reason in relation to Audio sync issues? I always use frame controls to de-interlace. I will read this chapter. I’m guessing it must have something to do with the ‘Retiming control’ as the timing of the audio was out?
    Thanks for your kind advice
  • Daniel Low
    September 4, 2009 at 7:00 am
    [James Bayliss-Smith] “Why did you suggest I read the chapter on Frame controls”
    Because you said that you were unhappy with the quality of playback
    [James Bayliss-Smith] “I captured HDV footage as ProRes 422 (Normal Quality) straight into Final Cut Pro. “
    How did you get it to compressor?
    “There’s no chance that the iPhone is going to get any significant market share. No chance.”
    Steve Ballmer To USA Today
    September 4, 2009 at 7:14 am
    I just read the chapter on frame controls and there seems to be nothing in there that would make the audio go out of sync. Still a mystery
    James
    September 4, 2009 at 7:15 am
    I got the video into compressor by exporting a Quicktime Movie “current settings” then dragged that into compressor
    September 4, 2009 at 7:20 am
    I have just realised something that may be of interest. Due to capturing a portion of one tape at a later date than all the rest I have realised that there is 1 clip in my sequence that was captured as ProRes (HQ) all the rest is just ProRes. I’m not sure why this would be a problem as I’m sure Final Cut 6 can handle different sources in the time line.
    September 4, 2009 at 5:42 pm
    Hi Daniel, any ideas?
Page 2 of 2
