Activity Forums Apple Final Cut Pro Audio Sync Issues In FCP
  • Jeremy Garchow
    March 21, 2014 at 4:23 pm
    Also, here’s another thread for reference:
    https://forums.creativecow.net/thread/344/28167#28167
    Jeremy
  • Bret Williams
    March 21, 2014 at 4:42 pm
    Just over 5 minutes.
  • Ray Junior
    March 21, 2014 at 5:05 pm
    Hi Jeremy-
    I did exactly as you said- loaded the 29.97 cam file first, added the 30 clip, selected it, retimed for auto speed, set it for the (custom) exact length of the 29.97 piece.
    now instead of the top clip (the iphone clip) being a little too long, now it’s a little too short. you can see it in this screen shot:
    https://www.rayjuniorshow.com/stockpile/pix/fcp-weird.jpg
    as you can see the mouse cursor is hovering where it says the time is 16:23:22 – which is exactly what i set the top (iphone) clip for. it should be the exact same length shouldn’t it?
    also, the audio is now COMPLETELY off! before it was just slightly off
  • Jeremy Garchow
    March 21, 2014 at 5:25 pm
    Thanks for the picture.
    Do the clips start and end at the exact same time and are the same length?
  • Ray Junior
    March 21, 2014 at 5:28 pm
    The raw footage does not, but the clips KINDA do. here’s what I mean:
    We used an old school clap board so I created a marker at the correct moment in both clips, then cut off the video prior to those intro markers. so they started at the exact same place on the timeline.
    then, at the end, i found an identical moment in both clips and marked it in both, and cut off any trailing video.
    so while they both started in the same place, and both contained the exact same material, the iphone clip was a little longer.
    then i applied the changes you suggested and the iphone clip ended up a little shorter instead.
    I muted the audio on the iphone clip (the better audio is from the other camera) and at it’s just as it was before in one respect: the audio at the beginning is pretty much in sync, but by the time you get to the end its out of sync.
    however, now its even worse – its WAY out of sync.
    so i’m confused
  • Jeremy Garchow
    March 21, 2014 at 5:56 pm
    [Ray Junior] “so i’m confused”
    Yes, it’s confusing.
    Now, take that green retiming bar, and drag it so it’s the same length as the bottom clip.
    In sync?
  • Ray Junior
    March 21, 2014 at 6:01 pm
    AND VOILA! YOU’RE A FREAKIN GENIUS!
    thank you!
Page 2 of 2
