Activity Forums Apple Final Cut Pro Legacy Audio Sync Issue FCP7
  • Michael Gissing
    November 25, 2015 at 10:41 pm
    [David Mignano]”Does that tell you anything about what might be wrong? I’m converting a clip to 23.976 to give that a shot.
    I also checked my EZ set up and I have the frame rate at 24 fps.
    The sequence preset is DV NTSC 48 khz. ”
    You are mighty close to 4% which indicates the audio may be stamped as 25fps and the pictures may well be true 24. If your footage is 1920 x 1080 ProRes then the sequence preset should be the same. DV NTSC is 29.97.
    So if we can get all the ducks lined up in a row and there is drift around .1% not 4% then the final thing will be 23.98 versus 24
Page 2 of 2
