Activity Forums Adobe Premiere Pro audio left channel only
  • Rob Van
    December 9, 2017 at 4:34 pm
    Hello people, I’m cutting on Premiere CC 12.0 and am finding that all multicam sequences are playing only left channel, while other sections of my sequence are playing stereo mix (which is what I need). The multicam sequences are sync’d with 4-6 tracks of mixer audio, not camera. Please advise? I see this was fixed awhile back for those who are fine with a mono mix sequence but this is going to broadcast. Thank you!
  • Niklas Lagstrom
    February 3, 2018 at 6:43 am
    Probably you have already solved this problem, but there might still be people out there who will encounter it, therefore I reply here ☺
    I had the same problem with a fresh installation of Premiere and found out that Premieres multicam sequence preset is a Arri Alexa. If you just create one new multicam sequence with for example DSLR 1080p it will default that in the future. And that preset worked for me filming multicam with 2 iphones and external mono audio.
Page 2 of 2
