Activity › Forums › Adobe Audition › audio compression prior to recording
Emmett Andrews replied 15 years, 7 months ago 6 Members · 11 Replies
Emmett Andrews
February 10, 2011 at 6:56 pmNo, unless your converters are garbage, S/N isn’t an issue. Whatever you’re recording likely has less than 30dB of usable dynamic range. We’re not in 1984 anymore, where 30dB plus 18 dB of headroom would put you close to the noise floor. As far as your background noise, it makes no difference when you compress, the noise will raise. There is no benefit to compressing on the way in.
