Activity Forums Audio Audio Clips with Speed FX
  • Audio Clips with Speed FX
    Posted by Robert Gilbert on December 21, 2023 at 3:52 pm
    Hello everyone! Could anyone please tell me why some of my ADR audio clips, which I stretched to fit the lip synch, were thereby corrupted with excess reverb?
    Yes, I had remembered to click the “maintain audio pitch” box. It seems I must now remove the speed fx and then try to synch them in Audition, but since there are many of them, I wonder if there might be an easier solution (like removing the reverb, maybe?). As you can see I don’t know much about working with audio. Your advice will be much appreciated. Thanks!
    Robert Gilbert replied 2 years, 9 months ago 3 Members · 11 Replies
  • 11 Replies
  • Ty Ford
    December 21, 2023 at 5:11 pm
    Hi Bob and welcome to the Cow Audio Forum. I’ve never tried to do that. If you were stretching, than the computer had to throw something in there. Can you please post an example or send me one at tyford@tyford.com?
    Ty Ford
    Cow Audio Forum Leader
  • John Fishback
    December 21, 2023 at 5:14 pm
    I don’t know why you’re getting reverb when you stretch the clips. For ADR, I’ve always used ReVoice Pro. It’s simple. Place the original clip on a guide track in ReVoice then the ADR clip on another track in ReVoice. ReVoice exactly conforms the ADR to the guide track. You can make the match “looser” if exact sounds wrong. It adjusts timing & pitch perfectly.
  • Robert Gilbert
    December 21, 2023 at 5:46 pm
    Thank you very much, John. I’ll look into Revoice. Merry Christmas!
  • Robert Gilbert
    December 21, 2023 at 5:50 pm
    Thank you very much, Ty! Is there an easy way I can send you the audio clip? I actually tried to copy and paste it but it seems it’s not that easy. Do I need to export it? If so, what export settings should I use, please? Thanks.
  • Ty Ford
    December 21, 2023 at 11:59 pm
    email or via (free) we transfer.
    Regards,
    Ty
  • Ty Ford
    December 25, 2023 at 3:01 am
    Hi Bob,
    That’s not reverb, that’s what’s called delay. Still doesn’t tell me why, but something is out of line. Or you have the original and the altered version both playing at the same time.
  • Robert Gilbert
    December 25, 2023 at 5:53 pm
    Could you suggest a remedy? Thanks and Merry Christmas!
  • Ty Ford
    December 25, 2023 at 6:01 pm
    Try Undoing what you’ve done and try again.
  • Robert Gilbert
    December 25, 2023 at 8:48 pm
    Using your info I searched with the word “delay” (which someone else called “phasing”). I found a partial remedy from someone who said to do the speed effect with the “maintain audio pitch” box unchecked, and then fix the pitch with AUpitch. It worked but the results are a little scratchy. I wonder if NewAUpitch would be better. Any ideas?
  • Ty Ford
    December 25, 2023 at 8:55 pm
    Phasing is a little different. Your double tracks are not really close enough to call it phasing. I do not use Adobe Audition. I suggest you try their online support.
    https://creativecow.net/forums/forum/adobe-audition/
    Regards and Merry Xmas,
    Ty Ford
