Activity › Forums › AJA Video Systems › Audio clicks & pops from FCP through AJA IoLA – not there until the AJA box
  • Jeremy Garchow
    February 23, 2006 at 10:30 pm
    I also meant to tell you as another variable, switch the audio tracks (put ch1 in ch 4 and vice versa) in FCP and see if you still get clicking in ch4 of the deck.
    What has AJA said? They should swap put a bad unit for you immediately.
    G5 Dual 2Ghz <> 4GB RAM <> FCP 5.04 <> Kona 2
    ATTO 42XS <> Huge Systems 4105 Fibre
    OS 10.4.2 <> QT 7.0.3
  • Bob Zelin
    February 24, 2006 at 12:14 am
    Mr Thrillcat –
    you have just powered up your system, you are sitting there, monitoring the
    output of your AJA I/O, and you are doing NOTHING, and you hear random pops and clicks coming out of your speakers. You raise the faders on your mixer
    from the AJA I/O, and the pops and clicks increase in volume – correct?
    You have a defective AJA I/O box. I just had this exact situation. I had the luxury of having 3 systems at this client, and I moved the mystery popping box into another edit room, and the pops and clicks moved with the AJA I/O box. I know how frustrating this can be to diagnose when you only have one system, and one AJA I/O box.
    Request another unit.
    Bob Zelin
  • Michael
    March 20, 2006 at 5:28 pm
    The other possibility is that your audio sync isn’t stable. Pops in a digital line can occur if there’s an unstable clock source or a defective cable. I used to get them occasionally when using the optical outs and my word clock wasn’t stable or in sync. Selecting the optical line for sync would clear up the trouble. You’re using AES, so I’d make sure the cable isn’t the problem.
    My 2 cents…
    -mjd
Page 2 of 2
