Activity › Forums › DaVinci Resolve › Attention resolve 8 beta users.
  • Vladimir Kucherov
    June 23, 2011 at 4:40 am
    Well the math for that certainly sounds like it makes sense – double the GPU, double the performance.
    What’s interesting though is that even your beefy system can’t go below 3-radius.
  • Gabriele Turchi
    June 23, 2011 at 5:10 am
    Peter ,
    when Resolve landed on OSX at this price i was very very skeptic about the future development of this tool …support etc…
    what can i say ….in less than a year Resolve and the BMD team demonstrated to be one of the best post production tool in the market ,
    i want to honestly say thank you for all have you done in such short amount of time and for listening to us so focused on our needs .
    V7 to V8 is a quantum Leap ,
    thank you for that and looking forward to the future .
    g
  • Mike Most
    June 23, 2011 at 5:14 am
    Thanks Peter, that’s really great news. Greatly appreciate the return of the mix mode. I’ll know now to expect the transforms a bit down the road and I won’t mention it again ;-D.
    Communication is a great thing. Apple can definitely learn some lessons from you guys….
  • Jose Lomeña
    June 23, 2011 at 8:33 am
    New Macpro + Lion with support for gtx480… Gtx480 has x2 cores of a 285. Lion DP4 has support for GTX480 with full features.
    And I think we will see nvidia cards or cuda proccesor through thunderbolt in a near future… but this info is only my opinion.
    saludos,
    Jose.
  • Paul Nordin
    June 23, 2011 at 6:01 pm
    Yep the GTX480 will make a big improvement to be sure
    _______________________
    El Mundo Bueno Studios
    Film * Audio
    http://www.EMBstudios.com
    Emeryville, CA
  • Darin Wooldridge
    June 23, 2011 at 6:34 pm
    Try right clicking next to your node tree, click apply alpha. Then draw the node to the lower box that just appeared.
    NOTE: The comments above are strictly mine, and may not necessarily
    represent those of my employers.
    Darin Wooldridge
    Colorist / Technical Strategist
    818-653-3918-cell
    dwooldridge@mac.com
    check me out at https://www.facebook.com/pages/Davinci-Resolve-Colorist/117363011609028?ref=….
  • Darin Wooldridge
    June 23, 2011 at 9:16 pm
    Thanks Blase,
    I have a few questions.. Shall I email them to you???
    Darin Wooldridge
    818-653-3918-cell
    dwooldridge@mac.com
  • Jose Lomeña
    June 23, 2011 at 11:16 pm
    Thank you so much Blase for the info.
    I do a lot of green screen with resolve7 but only with mattes, and is dificult because i can’t make garbage to the matte node or a simple blur.
    Can you explain a little bit more about your workflow i apreciate it a lot!. I will start a feature in september that has a lot of vfx shots and it can be my solution!! Because i need to do this basic composition with resolve.
    Saludos,
    Jose.
  • Blase Theodore
    June 24, 2011 at 5:36 pm
    Pretty simple..
    Import an XML of media
    – greenscreen on v2, background plate on v1.
    On the GS layer, add a few parallel nodes.
    – Top will be grade for GS,
    – middle will be spill suppress layer
    – bottom will be base for alpha key
    Right click in node graph to add an alpha output
    – little rectangle appears on right of node graph
    Create a matte from the greenscreen
    – pull greenscreen on your bottom node,
    – combine alphas of multiple nodes if necessary
    – map matte output of those nodes to alpha output
    Remove green spill as necessary
    – on the middle node, pull a very liberal key on the greenscreen
    – use the curves – saturation tool to correct for spill
    You now have your plates comp’d color grade them to match accordingly.
    The key doesn’t do as well with hair, but for my shots it was fine. Of course you could simply use this technique as a temporary way to grade the plates and foreground, and still do your final comp as an effect.
    here’s the result of my shots..
    https://www.contact-di.com/clients/benjamin/vfx_preview_web.mov
    Cheers,
    Blase
  • Jose Lomeña
    June 24, 2011 at 10:55 pm
    Thank so much Blase, I’m very impatient to have v8 in my hands!!
Page 4 of 5
