Activity › Forums › Blackmagic Design › ATEM Television Studio QUESTIONS!
James Denham replied 11 years, 7 months ago 9 Members · 28 Replies
Carlos a. Vazquez ii
June 18, 2012 at 12:18 amOk
Thank you so much.
I t has to be done even ime still?
or once i do that will keep it forever?? -
June 19, 2012 at 6:15 pmOk
I did it!Richard
you need the usb cable to do the set up IP address to be hook up
Cause the settings are not done by the cat 5 they’re have to be done
Trough the USB very weird for me!
Any ways! Thanks for you’re help
And we keep in touch
I’m SHURE I will be reading you’re very interesting forum
And post I really learn a lot from you guys
And every body that wrights in you’re forum!
Once again! GRACIAS
If you ever come to Baja M Mexico, clet me know
I I’ll take you for the best fish hacks in town! 🙂
Talk to you soon! -
June 20, 2012 at 11:38 pmHy Rich
How come i only have two video inputs on my switcher?
that i can see my camera?
i mean the’re eight but only in 3 and 4 i’m able to see my camera?
1 and 2 does not get highlighted or does not give’s me the opcion of sd/ hd
or anything!
i went to settings, and played around but nothing!
any feedback??
thank you! -
June 26, 2012 at 2:12 amRchard
how yu doing
please, when i turn on my switcher
on the left han side does not appear
6 video inputs!
it only let me hook 3 and 4 inputs
1 and 2 are not high lighted
and 5 and 6 also does not show any
activity it does not let me do anything
like hook a camera or signal for test ( dvd ,blue ray video any source
for play back
once again
i only have access to inputs 3 and 4
any feedback please! -
Rafał Gieroń
August 19, 2012 at 9:54 pmHi Chris!
What about software like BoinxTv? I can’t see the ATEM source in this software using the USB 2.0 cable. Its work when I use HDMI program and Intensity Pro but this method is bad for speed of my MacPro.
Its any chance to stream from ATEM TS using USB 2.0 on MAC?Rafał Gieroń
LiveEventTv -
Mark Farnsworth
March 10, 2013 at 8:37 pmHey guys, after hours of frustration trying to get my macbook pro to connect the ATEM TVS software controller, I finally found the solution:
ATEM
IP 192.168.10.240 (this is the factory default)
Subnet 255.255,255.0
Gateway 192.168.10.1Mac Pro Ethernet port
IP 192.168.10.1
Subnet 255.255.255.0
Gateway (this is the tricky thing). Try 192.168.10.1 (yes.. I know seems odd). If there is any way to leave it bank…you could also try that (but I’d don’t think so)Then use your existing wifi settings unchanged.
What we want Is for your MacBook to see two different networks. One is setup to connect just between your Ethernet port and the ATEM. Then hopefully for all other routes (to the Internet) it will know to go via the wifi.
Hope this works magic for you like it did for me and thank you Liam Kennedy!
James Denham
February 10, 2015 at 4:34 amI wonder if you could help me out. I am trying to connect my macbook laptop to my ATEM TVS via ethernet. There is something I’m doing wrong in the IP address location because the ethernet is not being recognized. I can connect the switcher to my mac tower via ethernet and control it just fine. I’ve changed the IP address so many different ways on my network settings on my laptop, it seems I am having no luck. I’ve dealt with this issue many of times, and end up getting it connected most of the time, it’s just been a while, looking for any simple solutions to make this work. Wondering if you know the easiest approach to get my ethernet port to recognize the ATEM, any help would be appreciated.
