Aspect Ratios – 2.39:1 from 16:9 (1.78:1)
Will Brown replied 15 years, 7 months ago 3 Members · 12 Replies
John Rofrano
January 27, 2011 at 10:36 pm[Will Brown] “Ok, I see, with 1920×803 PAR1.0 in project settings, I have to use 1440×803 in the crop window.”
After setting the project resolution correctly to 1920 x 803 PAR 1.000 you go into the crop window and right-click and select Match Output Aspect. That’s all you need to do. Forget about what the crop settings are. Use match output aspect and Vegas will guarantee that there will be no black bars.
When you render, use the same settings as your project (1920 x 803 PAR 1.000).
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Will Brown
January 28, 2011 at 12:03 amAhhh, OK, thanks again John, I will print this off for future reference.
Your info has been invaluable.😉
Will.
