Activity Forums VEGAS Pro Aspect Ratio problems
  • John Rofrano
    July 27, 2008 at 5:38 pm
    > To obtain this on AVI, I have to actually resize the video. I prefer reducing it because making it bigger would see everything distorted.
    There is no need to reduce it. All of the information is there for 873×480 with absolutely no loss of quality. Widescreen pixels are wider (1.2121) and therefore the real resolution is actually 873×480. You can reduce it if you’d like but nothing will be distorted if you render at 873×480.
    > One last question: I’m doing a custom template 704×396. (it gives me 16:9, I calculated it) with a PAR of 1. If I want to include, let’s say, a 480p video (640×480), what is the PAR I would assign to that video?
    You need to crop the 16:9 in order to get 4:3. You cannot simply change the PAR. If you follow my advice and create 873×480 you will get the 480 video you want. If you want to cop to 4:3 then you must re-render the video with a 4:3 crop on the original 16:9.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
Page 2 of 2
