Activity Forums Apple Final Cut Pro Legacy Applying Kona to a 23.98 project
  • Jack Fox
    January 29, 2009 at 10:32 pm
    Shane,
    You said 23.98 is non-drop only, then why does the calculator that you recommend have a 23.98 drop option? I wonder if there are any other people or devices making the same mistake.
    jmf
  • Shane Ross
    January 29, 2009 at 10:34 pm
    I already told you…a few posts up…
    “The drop frame option in the calculator is only for making the conversion possible. DF 23.98 does not exist.”
    The DROP FRAME option on the calculator is ONLY there so that you can convert 23.98 NDF to DF to see what the timing will be. That’s it.
    Shane
  • Gary Adcock
    January 29, 2009 at 11:06 pm
    [Shane Ross] “23.98 is NON-DROP only…I have said this more than once. You cannot, through any Herculean effort, make that format DROP FRAME. “
    ALL frame rates below 29.97 are NON DROP.
    Drop frame became an issue in video.
    Shane is correct 23.98 CANNOT BE DROP FRAME – Film output has no need to drop frames.
    the VTR mechanism is physically slowed down to achieve this timing.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
    https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
Page 2 of 2
