Activity Forums Apple Final Cut Pro Apply an Effect to Top Layer Only
  • Don Smith
    December 27, 2015 at 5:04 pm
    Right click on the title effect to open it in motion. De-select the Title Background and save a copy. If the effect allows u to edit it u can defeat affecting all layers like this.
    NewsVideo.com
  • Steve Schoenbaum
    December 27, 2015 at 7:13 pm
    Thanks, Don. You know, I tried that before and it didn’t work but just realized that I also needed to de-select the transition out. Anyway, thanks and. although I’d like this choice to be embedded in the inspector in FC, I feel like I’ve gained a small measure of control back from Apple (even if it is on their terms!).
    FCP X 10.2.2
    MacBook Pro 10.10.5
  • Don Smith
    December 27, 2015 at 7:32 pm
    It maybe possible to Rig the Title Background and Publish a control to make the Title Background active or inactive but I haven’t tried to do that. I might experiment with that.
    NewsVideo.com
  • Ivo Fuentes
    June 13, 2016 at 3:59 am
    Thanks for the tip Ronny!
    I was having the same problem as the original thread.. a quick forum search, and stubbled on your comment.
    Tried it and worked.
    Awesome!
Page 3 of 3
