Activity › Forums › Compression Techniques › Apple Compressor 3 “unknown time remaining” WHY!??!
Hope Holmesby replied 13 years, 7 months ago 23 Members · 36 Replies
Aaron Ross
September 1, 2010 at 12:38 amMan, you are awesome, My batch monitor was full with awaiting processes. I deleted all of them and now everything is good. Thanks alot for the help…
Andrew Noon
September 29, 2011 at 8:25 pmI just ran in to the same problem and for me after reading this forum it was an easy fix. What I did was opened Compressor. Then went to Compressor>Reset Background Processing… My Internet Sharing was already off as some people previously mentioned to try. I went to System Preferences, then under Internet & Wireless, clicked Sharing, then deselected Web Sharing. I have no idea if deselecting Web Sharing contributed to fixing the issue. But this is what worked for me. I also deleted all of the project history in the compressor. Again, not sure if that contributed, but the whole process worked. I would suggest initially trying the Reset Background Processing, then go from there if that doesn’t fix your problem.
Thanks so much to everybody who commented in this thread, you are a huge help!
Stephen Cook
March 7, 2012 at 10:02 pmI had the same exact problem as above and followed all the steps. The only thing that fixed it and finally got me back and running was deleting all the old history projects. I think it was trying to run old failed projects again for some reason.
So just keep your History box clean before each project, no matter what. -
Linda Naks
January 7, 2013 at 3:47 pmDeleting the Batch Monitor’s and ALL Compressor prefs, emptying trash, shutting down, unhooking all drives, restarting w/zapping PRAM a few times, and then re-mounting all drives worked for me. Thanks to all at Creative Cow for YET AGAIN saving my life and keeping one more editor off the streets of LA!
Hope Holmesby
January 8, 2013 at 1:19 amLOL…oh boy….made me laugh, reading the part about ‘off the streets of LA”
used to work in LA too….know the feeling…sounds like you did a lot to get it going. probably you read the part about getting the repair thingy for compressor….that worked for me on the G5…must be one for intel Mac…or whatever you are running
its a special small program that u download. it had a bandaid on it…on the icon.
good luck dear. well done
__________________________________________________
Life is here to enjoy.
iMac 3.5 GHz Intel Core i7, 2TB; Mac OS 10.6.8, 16 GB RAM; 2 La Cie external HDs 1 TB each; After Effects CS5.5; Sound Track Pro 3.0.1; Final Cut Pro 7.0.3; Compressor 3.5.3
