Activity › Forums › Apple Final Cut Pro Legacy › Apple Compressor
Shane Ross
January 30, 2013 at 7:16 pmFor making a DVD, I always export a self contained QT file, using the sequence settings. Take that into Compressor, use the DVD BEST QUALITY preset…and take the result into DVD Studio pro for authoring.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Fernando Zuniga
January 30, 2013 at 11:59 pmHey Shane should I move anything on the interlaced in Compressor?
Shane Ross
January 31, 2013 at 12:01 amWell, if your footage isn’t interlaced (is the source footage interlaced?) then you shouldn’t need to deinterlace in Compressor. Heck, even making that sequence setting should have gotten rid of it.
Try doing nothing about it in Compressor…see what happens.
Shane
Little Frog Post
Fernando Zuniga
January 31, 2013 at 12:19 amShane, so from now on how do I capture HDV, since I film with a HDR-FX1000
I have FCP-Avid & Adobe Premiere. Thanks!!!! -
Fernando Zuniga
January 31, 2013 at 9:49 pmHey Shane ur advice work!! thanks a million.
Just 1 question, on Compressor should I leave everything alone in frame control ? -
Shane Ross
January 31, 2013 at 10:39 pmYes. Unless you are changing frame rates or frame sizes…leave that alone.
Shane
Little Frog Post
Fernando Zuniga
February 2, 2013 at 3:43 pmHey Shane, the project that I compress is done, but the HDV quality is not there, how do I compress it and burn it , to keep the HD quality.? Thanks.
Shane Ross
February 2, 2013 at 4:45 pmAh. For that you need to author a BluRay disc. DVDs are SD only. So now you need a BluRay burner, BluRay software like Roxio Toast or Adobe Encore. And then a BluRay player to watch it on.
Shane
Little Frog Post
