Activity › Forums › Creative Community Conversations › Any negatives to buying another 2011 17″ MBP in 2013?
Alex Donnelly replied 12 years, 12 months ago 3 Members · 13 Replies
Dave Gage
July 5, 2013 at 12:19 am[Gary Huff] “Are you using a generic eSATA card”
Sort of. I’m using the OWC Slim eSATA ExpressCard/34 Adapter. I was prepared to buy a Sonnet card since I’d heard good things about them for a few years, but two of the phone support guys at MacSales.com said that this would be as good based on a couple of years of customer feedback, especially since I only needed one port.[Gary Huff] “…with the Sonnet drivers?”
The first I had heard about the drivers was in the last couple of days via one of these threads. This appears to be it though-
https://www.sonnettech.com/support/kb/kb.php?cat=345&expand=&action=a3#a3I’ll give the driver a try, but I’m thinking that all along the problem may have been with the eSATA port on my OWC 2-drive RAID enclosure. Didn’t you say earlier that you weren’t using the driver?
Dave -
Gary Huff
July 5, 2013 at 3:57 pm[Dave Gage] “Didn’t you say earlier that you weren’t using the driver?”
Yes, I don’t know if the slim ExpressCard version requires a driver or not. Some do, some don’t (the other Sonnet SD card reader (the 21-in-1) didn’t require a driver, while the UHS-I reader did. So you might need a driver with the slim-line version of the eSATA card, while the Tempo-Pro doesn’t.
Alex Donnelly
September 13, 2013 at 11:12 amHi
I have just joined this forum (after years of lurking about looking for solutions) to ask a question about your Mac Book Pro early 2011 If I may?
I just bought the exact same model, from the Mac store refurbished, actually appears to have been used barely at all. Brand New Condition, with Lion and all firmware updates were not done, they were available to be downloaded with update checking which I did. And after that installed an SSD in main drive bay and 16 GB ram and Mountain Lion 10.8.4.
It appears to be running well, with temperatures in tolerance, CPU 40 to 50% celcius and fan speed at 2000 rpm’sh when doing basic things, all the time until I Use Final Cut X 10.0.9 to real time preview (busy project with lots of filters etc…) Real time preview in Motion 5 or even record the screen with Quick time and sound flower. (Firefox playing an HTML 5 video).
I am aware that the Radeon graphics card will get hot after continued use in these conditions and activate the fans. The temperatures I am seeing are about 75 to 80 celcius and fan hits about 5000 rpm ish. When render or use stops it quickly cools and is quiet again. From a look about the web this is normal for a MBP 17″
What has me a bit worried is that I also use an early 2011 15″ MBP with a quarter of the video memory (also radeon) for about a year now and while it reports similar temperatures in the same circumstances and even gets warmer according to at Monitor the fan does not hit the same speeds or volume as the 17″. One of the bonus’s of the 17 was apparently that it had better cooling with the larger frame.
I am going to go back to Lion with the original factory disk and test in that with at Monitor (the build that reads GPU and no longer works in 10.8) to specifically see what the GPU temps are and look about the web a bit more.
From what I can gather it is potentially normal behaviour (even though the 2011 15″ I use is quieter and fans run lower even when the machine is running hotter) or there is an issue with the GPU that could hopefully be fixed by better application of thermal paste (really dont want to have to do that myself) or send it back which is always a pain, where would one get one of these now rare models in such good condition again without braving ebay 🙂
Thanks in advance if you could comment on the normal operating behaviour of your early 2011 MBP 17″.
Alex
