Activity › Forums › Adobe Premiere Pro › Annoing things about PPro
Larry Asbell
August 24, 2013 at 7:52 pm[Alex Rod] “3) ah…I am still a little confused. When I get an audio clip where the left channel as NAT sound and the right channel the lavalier sound, I’d like to be able to separate it them to delete the NAT channel. Also, when I have clip with two channels, I’d like to be able to adjust the audio of both simultaneously.”
Just right click on your stereo clip in the timeline and select Audio Channels. Then under Source Channel where you see the words Right and Left, change the Right one to Left to hear only the channel 1 mic. Then change both source channels to Right to hear the Ch 2 mic. Leave it on the one you want. Since you’ll do this regularly, assign a shortcut (such as Control-A on a Mac) to the Modify Audio Channels command.
