Activity › Forums › Apple Final Cut Pro Legacy › Animated Graphic movement not smooth after render
  • Jeremy Doyle
    January 15, 2009 at 7:47 pm
    Is the graphic rendered as progressive frames? It should be rendered with frames set to lower.
    also as you note the 23.98 should be 29.97.
  • Paul Harb
    January 15, 2009 at 7:51 pm
    Ive tried rendering it to lower, upper, none….same issue…Im really thinking its the frame rate, although ive gotten stuff like this before in FCP5 and never had this issue.
    Paul
    Paul Harb-Producer/Director
    Wrong Beach Multimedia
    Dual 3.2 GHz Quad/10.5.5/8GIG RAM/FCP 6.0.4/QT 7.5.5
  • Jeremy Garchow
    January 15, 2009 at 8:12 pm
    I was going to say it the file is 23.98 instead of 23.976. Is your timeline frame rate 23.98?
  • Paul Harb
    January 15, 2009 at 9:13 pm
    Timeline is 29.97
  • Jeremy Garchow
    January 15, 2009 at 10:06 pm
    But the graphics is 23.98? There’s your problem. FCP does not add pulldown correctly when adding 23.98 material to a 29.97 timeline.
    Jeremy
  • Wilhelm Beck
    January 16, 2009 at 7:45 am
    For experimental purpose:
    Have you tried to make the AE render progressive?
    If the motion in FCP is smooth now you have confirmed deinterlacing as the issue.
  • Paul Harb
    January 16, 2009 at 6:04 pm
    Thks, I figured it was the frame rate….I had them send me the AE projects and i will export them.
    Paul
Page 2 of 2
