Activity › Forums › VEGAS Pro › Analog capture
  • Sammy63
    December 22, 2005 at 2:25 am
    Primary- Ultra DMA mode 5
    Secondary- Ultra DMA mode 2
  • Sammy63
    December 22, 2005 at 1:12 pm
    One last thing, my computer has a pentium 4, 2.6 ghz, 1.25 g ram.
    Is that enough? I don’t have the money to just go out and load up on ram if I’m not sure if that’s the problem or not.
  • Edward Troxel
    December 22, 2005 at 2:35 pm
    Your system sounds plenty capable for capturing video. How many hard drives do you have?
    Edward Troxel
    JETDV Scripts
  • Laszlo Kovacs
    December 22, 2005 at 2:50 pm
    What kind of firewire do you use?
    Onboard/standalone PCI?
    Chipset?
    If You use standalone PCI FW, try it in another
    slot – there may be some IRQ conflict.
    How often do you defrag your drives?
    By(t)e
    Laca
  • Sammy63
    December 22, 2005 at 7:31 pm
    First of all, thanks for all of your input with this problem. I never expected this much attention for my problem. You guys have been great.
    To answer all the questions:
    I have three hard drives- Master 160g, secondary 200g, and a hot swappable 300g. All are 7200 rpm I believe, and I use one of the secondary drives when I’m capturing. I do a football video for our local high school every year and use up a lot of space.
    I defrag those hard drives quite often (at least monthly) and had just defragged them before doing this latest capturing.
    As far as the firewire goes, I have no idea. I didn’t even know there were different ones, but you bring up an interesting thought. I know I have several firewire ports but have for the life of this computer always used the one in the front for convenience.
    I will definitely try one of them in the back. Wouldn’t that be great if that’s all it was?
    Once again guys, thanks so much. Sam
  • Laszlo Kovacs
    December 22, 2005 at 10:52 pm
    Ooops, that could be a bottleneck.
    UDMA, Max transfer rate MB/s
    Mode 0, 16.7
    Mode 1, 25.0
    Mode 2, 33.3
    Mode 3, 44.4
    Mode 4, 66.7
    Mode 5, 100.0
    If your drive is really a 7200 rpm, should be
    capable to mode 4 at least.
    Either your dirve is defect, or it’s cable
    is not a 80 conductor wire.
    Try to capture to the drive that works in mode 5,
    and see what happens.
    Best regards.
    By(t)e
    Laca
Page 2 of 2
