Activity › Forums › AJA Video Systems › Am I being electrocuted?
Jesus Ali
July 1, 2008 at 9:22 pm[Walter Biscardi, Jr.] We only use the breakout box on all our Konas as it’s just a lot easier and more robust than a snake of cables.
I was looking at the photos of your edit bays on your website. When you use Anthro furniture have you used their 1, 3, or 9 U rack mounts?
Thanks. Jesus.
Walter Biscardi
July 1, 2008 at 9:25 pm[Jesus Ali] “Can those BNC connections be changed while the unit is powered up?”
Yes.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
Read my Blog!
Gary Adcock
July 1, 2008 at 11:52 pm[Jesus Ali] “Can those BNC connections be changed while the unit is powered up? “
everything EXECPT the FW connection are usable while powered up.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
Inside look at the IoHD -
Ramona Howard
July 2, 2008 at 12:25 amJesus,
I would highly recommend the $300 breakout box. The system will be less likely to endure damage using the Kbox vs a direct connection to the I/O board, but be weary that even with the Kbox, problems can be had for those not using proper practices or caution.
Better to replace a $300 Kbox than a $2500 Kona card. In addition you will get the analog ports that you might find very useful. Sorry can’t recommend the mounting as all our clients install in full racks.
Cheers,
Ramona
