Activity Forums Adobe After Effects Alt drag replace NOT working
  • Ridley Walker
    May 23, 2013 at 7:08 pm
    Have the anchor point, position or scale of the layers been changed? If so, what happens when you reset these to their default values?
  • Keith Steadman
    July 10, 2015 at 4:18 pm
    I have had the same issue but I solved it on my comp..I only been using it for a few weeks so It may have been just luck.
    I got 8 comps all titled sheets 1 to 8
    I used Alt + Drag to drag a pic on to the solid layer in sheet 3 which worked..but it wouldn’t work in the other sheets..it just kept wanting to place it above the solid.
    so I just clicked on the solid then held Alt and left clicked on my picture and then it let me replace my solid
    hope that helps
Page 3 of 3
