Activity Forums Maxon Cinema 4D Alpha map shadow problem
  • Brian Jones
    April 26, 2007 at 12:14 am
    Weird… the bump material is Mixing is there any bump in the other materials? As a test I would make card top a single surface object (delete the sides and bottom of the box), make sure the polys are aligned and facing the camera (with the card closed) then render again to see what it does.
Page 2 of 2
