Activity › Forums › Apple Final Cut Pro Legacy › ALL HELP NEEDED DUE TOMORROW!!!
Jeremy Garchow replied 19 years, 2 months ago 12 Members · 40 Replies
Elliot Pollaro
July 18, 2007 at 11:24 pmIt played back fine on both… so it must be the program im using to burn DVDs… im going to write down the encoding settings i use over there and repost in a second. I will need help on correcting them. Thanks!!
Elliot
Elliot Pollaro
July 18, 2007 at 11:31 pmTell me if these are correct, or if you would change something to keep my show from flickering.
Layers: Single
Transcode Speed: Medium
Theres 4.32 GB of Data to be put on the CD.Encode settings:
High quality CBR (8000kbps)
thats all of the settings… program is Sonic DVD Pro
help!!
Tim Vaughan
July 18, 2007 at 11:58 pmI didn’t read through all the posts, so I am not sure if this answer has been said. But I’ve always found it essential when working with pictures to always delete the render files after changes have been made, and re-render everything from scratch. I’ve seen it where the smallest change with a render fix jitter, but when I deleted the render queu and started a fresh render, the problem was fixed. Hope this helps
Tim
Rafael Amador
July 19, 2007 at 1:16 amAre you exporting the audio as AIFF? Although the video data-rate is not too high, try Dolby.
Rafael -
Jeremy Garchow
July 19, 2007 at 3:19 amIf you are going to use Sonic to burn the DVD, then I’d probably let SOnic do the encoding.
Export a self contained movie from FCP and bring it over to your Sonic machine.
Jeremy
Ed Dooley
July 19, 2007 at 4:39 amJust thought I’d roll credits on this one:
A jujuelliot Production
Executive Produder- JeremyG
Producer- Shane Ross
Director- Rafalaos
Best Boy- Mortimer Heathcliff
Gaffer- Lightning Ad (seemed so obvious)
Co-Executive Producer- David Roth Weiss
Curmudgeon- Ed Dooley
Grip- ThaxNo FCP users were harmed during this production.
Jeremy Garchow
July 19, 2007 at 4:52 am[Ed Dooley] “Just thought I’d roll credits on this one:”
Hilarious!
