Activity Forums Sony Cameras Aliasing/twittering EX1
  • Steve Connor
    March 1, 2009 at 8:08 pm
    Use the “mpeg2 6.2mbps 1 pass setting” in the “DVD Fastest encode 90 minutes” folder and the dolby digital professional 2.0 setting for the audio
    Steve Connor
    Adrenalin Television
    Have you tried “Search Posts”? Enlightenment may be there.
  • Olly Lawer
    March 1, 2009 at 8:15 pm
    Great, I will try this.
    Are you increasing the average bit rate for better quality and changing the frame controls in any way?
  • Steve Connor
    March 1, 2009 at 8:20 pm
    depending on the length of the video I may tweak the data rate to 6.7 or 6.8
    Steve Connor
  • Olly Lawer
    March 1, 2009 at 9:11 pm
    Thanks for this workflow. Image looks a LOT better then it did the first time.
    Just to throw another workflow I discovered into the mix. Have you tried this?
    Edit as normal in HD in FCP
    Choose File>Export to XDCAM. This will create a BAPV folder with your project in it.
    Launch XDCAM EX Clip Browser and open the BAPV folder
    Choose File>Export>Raw DV
    Use the newly created DV file to create your DVD using standard DVD software.
    Apparently people are getting some very good results.
  • Steve Connor
    March 1, 2009 at 10:23 pm
    I wouldn’t encode to SD from a DV codec, wastes information, at least I’d convert to DV50
    Steve Connor
  • Michael Slowe
    March 2, 2009 at 2:32 pm
    Very good thread, one of the best for years, thanks fellows.
    I have had brilliant DVD’s from the EX1 but, I have to say, the best were from material shot in the SP mode (HDV)! I then upscaled through Convergent Design’s box to HD and edited in Media 100. That application does a really good downscale and then the DVD is encoded with BitVice (VBR ave. 7.5, formatted in Studio Pro and burnt in Toast. I am sure that BitVice does a far better job in encoding than does Compressor.
    Lately, now I’m shooting in the HQ mode, I have experienced all the edge twitter described in the thread. Obviously the camera is too good! I propose now to experiment with the detail turned down to -20 as suggested and hope for improved DVD quality. I have compared the BitVice downscale with that in Media 100 and the latter is visibly superior.
    Michael Slowe
  • Olly Lawer
    March 2, 2009 at 8:06 pm
    Hi Michael,
    It has been hugely beneficial. I have been searching forums for the answers for many days and not found my answer, until this thread.
    I will try shooting in SP mode and see what results I get from that, but I have to say, the results look pretty good from Steve’s workflow. Maybe a little bit blurred on low light shots, but then again, that could be my shooting.
    For information, when I turned the detail off, I experienced no twitter/aliasing at all. Although I am going to test the camera again tomorrow by burning a variation of shots, SP, HQ, Progressive/Interlaced with varying degrees of detail and see what results I get.
Page 3 of 3
