Activity › Forums › Compression Techniques › Aliasing when I compress .flv with deinterlacing
Eric Olson replied 16 years, 10 months ago 2 Members · 15 Replies
Daniel Low
November 8, 2009 at 10:45 pmIt’s easy to blame the Avid but there you have it.
Try an AE project at 640×480 square pixel and see if you get the same result.
p.s. what avid system are you using?
“There’s no chance that the iPhone is going to get any significant market share. No chance.”
Steve Ballmer To USA Today: 30 April 2007“We and Apple are neck and neck and we’re chasing the two
other players,”
Steve Ballmer, referring to Nokia and Research in Motion. October 6th 2009 -
Eric Olson
November 8, 2009 at 11:06 pm -
Eric Olson
November 8, 2009 at 11:44 pmProblem appears to be with export compression/encoding because when I render out as QT Ref the file looks fine.
EO
Daniel Low
November 8, 2009 at 11:51 pmQT ref just uses the same settings as you have in the Avid sequence. Flix is far from the greatest encoder. Do you have access to anything else?
other players,”
Eric Olson
November 9, 2009 at 12:02 amI just realized that the version of QT I’m using is not compatible with Avid Xpress Pro 4.6. Need to reinstall 6.5.1 and see if that fixes the other issue first. Then I’ll try to reencode.
EO
