Activity › Forums › AJA Video Systems › AJA Xena LSe editing experience
Shawn michael Lee
July 26, 2006 at 1:48 pmI haven’t found a workaround for the “low system memory”, or shutdown issues. I have done more tests and found that I get these problems even when I work in an entirely NTSC DV project with NTSC DV selected from the beginning. It just seems that something since the AJA install has started a conflict with all of my formerly DV projects.
I plan to uninstall AJA entirely, then attempt to open the DV projects and see if the problems still occur. That should narrow it down, hopefully. I’ll keep you informed.
Dkh Lai
July 26, 2006 at 3:14 pmHi Lowry,
Thanks for the prompt respond. I am having the same
problem. Even though I am in a PAL environment, I am
having all the problems you faced including opening
a normal DV project. I have tried unsintalling AJA
(including take away the LSe card)Then, Premiere
reacted normal again without any problems.I am pretty sure the support team is working on this issue,
sincerely hope there will be a new update soon.just my 2 cents experience
Daniel
