Activity › Forums › Adobe After Effects › After Effects CC won’t stop during RAM preview
Michael Szalapski replied 11 years, 1 month ago 6 Members · 17 Replies
Cassius Marques
June 10, 2015 at 7:17 pmcould you turn off every audio and try to ram preview again? Better yet, can you temporarily replace every footage that has audio with a solid?
Eddy Rose
June 10, 2015 at 8:27 pmNone of my layers or any of the layers in the precomps I’m using have audio.
Eddy Rose
June 10, 2015 at 10:45 pmWORKAROUND FOUND
Okay, so I have no idea how to fix this issue but I have found a way to work around it. I go to the folder where my project file is located and double click it as if I were opening it. This process seems to “shock” AE out of the RAM preview.
Travis Lowell
June 17, 2015 at 2:59 pmWorking off a server might be the problem. I always work locally, especially dealing with footage. If I work with footage off a server, it gets pretty slow. I would work locally first, then save everything back to your server when you are done.
Benjamin Brown
July 28, 2015 at 1:19 pmIm having the exact same issue-let me know if anyone ever gives you a real answer to this question.
Benjamin Brown
July 28, 2015 at 1:20 pmAnd Im not working from a server and all my settings are as they should be-as far as I can tell its a bug. It doesn’t always do it if I preview in quarter instead of full.
Michael Szalapski
July 28, 2015 at 2:30 pmWhat (exact) version number of AE are you using? 13.2.0? 13.5.0? 13.5.1?
Previews are very different between 13.2 and 13.5 and 13.5.1 fixed a lot of the bugs in the new preview system.– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
