Activity › Forums › Adobe After Effects › Affter Effects: Importing MPEG 4 video
Vincent James replied 17 years, 1 month ago 5 Members · 12 Replies
Adolfo Rozenfeld
July 31, 2009 at 7:55 pmHello, Jerome.
I have written about this many times recently. But I don’t mind doing it once more 🙂
AE CS4 is a 32-bit application that runs better on 64-bit systems.
The main advantage of a 64-bit application is addressing more than 4 GB of RAM at a time.
AE CS4 takes advantage of more than that amount, by launching a rendering instance for each processor/core in your machine. So, if you had a quad core machine, for example, it could use up to 16 GB of RAM (4 GB per rendering instance).
But ultimately, yes, a 64-bit version of AE would allow longer RAM previews and better performance with with very large frame dimensions for Comps or source elements, if you had a ton of RAM to take advantage of. If you don’t have a ton of RAM, there isn’t any practical advantage to 64-bit computing.Adolfo Rozenfeld · Adobe
Vincent James
August 13, 2009 at 5:56 pmTry converting MPEG4 to other formats using Super Video Converter.
I normally use for my Nokia mobile.Like you,I also had probs importing MPEG4 video into After Effects and this worked for me
Free from https://www.techiechips.com/how-to-use-super-video-converter/
