Activity › Forums › Adobe After Effects › AE/Media Encoder: The best Workstation Configuration
Michael Trenton replied 10 years ago 10 Members · 17 Replies
Todd Kopriva
March 27, 2014 at 4:59 pm> If AE is called, then why wouldn’t AE use it’s typical resourcing (i.e. multi-thread) to render?
Because that would defeat the purpose of using AME as a background rendering application.
When you use Render Multiple Frames Simultaneously multiprocessing, you are telling After Effects to start many instances of itself in the background to render frames. This will take over your machine, and that is a good thing. You do _not_ want that to happen when you are rendering something in the background and continuing work on another composition, which is the workflow that rendering directly through AME is intended for.
After Effects team blog
Bill Lake
March 27, 2014 at 6:26 pmTodd- Can you point me to some documentation on this? I’d like to understand the technology on this better.
My goal is often to render to final file as quickly as possible, once the comp, or a set of comps is completed. I find that if I generate a series of comps in AE (without rendering) and then drag them all to the AME queue, that I complete the entire render phase more quickly than if I first rendered to an uncompressed file in AE and then re-encode with AME. The AME final render’s always are a higher quality (2 pass encoding) and much smaller file size. Now, my comps are not very complicated, so maybe that’s the reason. Most of mine are 2d motion graphics, character animation compositions, logo openers (3d and effects) and such.
Where can I find out exactly how this works, software-wise.
-BL
Todd Kopriva
March 27, 2014 at 6:37 pm> I find that if I generate a series of comps in AE (without rendering) and then drag them all to the AME queue, that I complete the entire render phase more quickly than if I first rendered to an uncompressed file in AE and then re-encode with AME.
Then you’re probably not using Render Multiple Frames Simultaneously multiprocessing.
Documentation on that feature is in After Effects Help:
https://helpx.adobe.com/after-effects/using/memory-storage1.htmlSee this page for resources about making After Effects work faster: https://adobe.ly/eV2zE7
Marc Lindeman
September 7, 2015 at 10:39 pmI like this answer, but having trouble looking for an updated list of best practices when buying an HP workstation for AE CC2015
And Are we not now into an HP Z820 for best performances and up-gradable builds
Wallace Adrian d’alessio
August 13, 2016 at 3:55 amIt is now 2016 and this issue is muddier than ever. Adobe lists and nVidia lists don’t match.
The Cards on the Adobe list for GTX are all obsolete ( as are many of the others listed)
But they are available on Amazon used. (!?)
There is a lot of change and conflicting info on AE use of any card. What was simple a few years ago is now a mine field.
DON’T buy a Quadro K2200 for After Effects in any case.
.Adrian D\’Alessio aka; Fluxstringer
fluxstringer@gmail.com
https://www.facebook.com/FluxStringer
https://www.linkedin.com/in/fluxstreamcommunicationshttps://twitter.com/FluxStringer
https://mog.com/FluxMuse -
Jay Budzilowski
September 14, 2016 at 4:44 pmI would also like an answer for 2016…preferably the best workstation/gpu (PC or Mac) for strictly encoding/transcoding with AME.
Michael Trenton
September 14, 2016 at 6:19 pm[Wallace Adrian D'Alessio] “It is now 2016 and this issue is muddier than ever. Adobe lists and nVidia lists don’t match.
DON’T buy a Quadro K2200 for After Effects in any case.”
I’d also like to add DON’T buy Geforce GTX 1070 as this card is not supported in After Effects.
I made the mistake of buying a brand new GTX 1070 a couple of months ago to replace my five year old GTX 580 and speed up work in After Effects and Premiere Pro. Unfortunately the card is unsupported in AE and using it leads to error messages and causes AE to crash. In Premiere the card performs no better than my old GTX 580 (rendering speeds being virtually identical). Seems I’d be better off keeping my old graphics card instead, but I’m hoping Adobe will address this and add support for newer Geforce GTX cards soon.
