Activity › Forums › Adobe After Effects › AE stops rendering the time line
Carlos Dee
June 26, 2012 at 9:29 amim having the same problem with thiw did you ever figure it out? heres what im running on
Mac pro 12 core 2.4ghz 12gb Ram 4TB Solid State CS6 and im running Mac OS 10.6.8 the video card is the ati 5770
I keep getting the need more than 2 frames to do ram preview and when i hit 0 and have the timeline marker at the begining it renders a few frames, I do have some footage later down the timeline and its in prores 422 but ive never had a problem with this before and i dont have alot of pluging or too many things going on in my comp any help???
Carlos Dee
June 26, 2012 at 9:33 amI forgot to also add, when i do a render queue and try to render as prores 422 it just goest straight through the timeline and only renders out what i had in the timeline as green everything else that should have also been rendered doesnt render and yes i do have the “b” and “n” set correctly for the in and out points
