Activity › Forums › Adobe After Effects › AE Rendering Problem – Text & Vectors
Deborah Mcfarlin replied 13 years, 8 months ago 3 Members · 12 Replies
Conrad Olson
January 11, 2013 at 10:04 pmYou will need a hardware blu-ray burner and specific blank blu-ray discs. I think you can use Adobe Encore to author the disc.
When you tired to used the laptop to play the file back what format was the file you were trying to play? If you had rendered it out uncompressed most laptops would struggle to play it. You can take that uncompressed file and use Adobe Media Encoder (different application part of the CS Suite) to compress that file into a H.264 format. This will make a much smaller file size that should still look pretty good and play back better. You could then loop this in your media player.
Deborah Mcfarlin
January 11, 2013 at 11:34 pmOkay, so it sounds like the laptop is the path of least resistance if I can reduce the file so real-time playback is feasible. Thanks everyone, for all your advise and support!
