Activity › Forums › Apple Final Cut Pro › Advice: Filmed in 24 and need to export to 29
  • Doug Metz
    September 12, 2018 at 9:50 pm
    Personally, I prefer to edit native and conform later.
    I need to reuse material frequently, and don’t want to have to remove extra frames or dig out the source media and re-cut from scratch. Cutting natively makes this work smoothly – drives me crazy to see a beautiful pan ruined by notchy playback due to added or missing frames. With talking heads, you don’t really notice.
    I’ll add the caveat that most of what I do doesn’t go to broadcast (sometimes, but not usually). Mostly corporate, live events, internal, and web. Frame rate can be what it is in these cases.
    If I have a project with multiple frame rates, I’ll weigh the predominant media with the deliverable spec and find middle ground.
    Doug Metz
    Anode
  • Bret Williams
    September 13, 2018 at 7:13 am
    Drop the final 24(23.98)p Master into a 29.97i interlaced timeline. FCPX will convert the pull down on the fly. Export and you’re done. Compressor will just introduce confusion and human error. You can check the interlacing in the viewer by setting the window to show both fields and 100% scale and stepping through. Youll see a pattern of 3 full frames and then 2 interlaced frames.
    _______________________________________________________________________
    https://BretFX.com FCPX Plugins & Templates for Editors & Motion Graphics Artists
    Hang Tag https://bretfx.com/product/hang-tag
    Overshoot Text https://bretfx.com/product/overshoot-text/
    Outliner https://bretfx.com/product/outliner/
    Clock Maker https://bretfx.com/product/bretfx-clock-maker/
  • Suzi P.
    September 14, 2018 at 1:31 pm
    Thanks, Bret! So you’re saying edit natively on a 24 AND THEN drop into a 29.97 and let FCPX do it’s thing? Do you have thoughts on optical flow?
    Suzi
  • Bret Williams
    September 14, 2018 at 1:42 pm
    You would definitely not use optical flow. You’re just doing what has been done forever. Taking 24fps and broadcasting it at 29.97i. That’s what TV does every day. Movies and shows are shot on film or video all the time and mastered at 24. Then you add pulldown and broadcast at either 60p (720p) or 60i(1080i). If you drop 24p into a 1080i timeline it will properly interlace it.
  • Eric Santiago
    September 14, 2018 at 3:19 pm
    [Bret Williams] “You would definitely not use optical flow. You’re just doing what has been done forever. Taking 24fps and broadcasting it at 29.97i. That’s what TV does every day”
    Agreed!
  • Suzi P.
    September 18, 2018 at 8:19 pm
    Thanks guys! I realize this is not a new thing but it’s new to me! Thank you for your time. Off to edit a 24 master and then let FCPX do the work and drop it into a 29.9
Page 2 of 2
