Activity › Forums › Adobe Premiere Pro › Adobe Mercury Playback NVIDIA only Legality
Drew Hoover replied 13 years, 4 months ago 7 Members · 12 Replies
Walter Soyka
May 26, 2012 at 12:08 pmThe new Kepler cards are built on a different architecture than the previous generation of Fermi cards. CUDA core counts are not directly comparable between the two.
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Drew Hoover
May 28, 2013 at 8:05 pmThe CUDA core counts are not comparable because the Kepler architecture (I’m getting a little out of my element here) eliminated the second (shader) clock in the Fermi cards. A unified clock speed means that everything is more efficient, but more cores are required. So blah blah blah, more CUDA cores does not mean better when comparing GTX5XX to GTX6XX.
You are overlooking some very important features that add a lot of value (or don’t, depending on your needs) to the Quadro.
1) Quadros use Error Correction Control (ECC) memory. Basically ECC memory is extremely reliable (and expensive) and doesn’t allow for errors when you’re say, applying a color grading effect to a clip. The card isn’t designed to be a speed demon, it’s designed to be accurate. No one cares about a compression artifact in one frame while playing Battlefield 3, so GTX cards don’t have ECC.
2) Quadros are supported with really specific drivers that enable them to work well with all kinds of 3D design programs.
3) Workstation GPUs are single slot cards, so you can easily stack a bunch into one server.
