Activity Forums Adobe Premiere Pro Adobe CC 2016.3 update
  • Jason Warfe
    June 22, 2016 at 4:31 pm
    My save file was completely messed up after the update. All my key frames and chroma work from a previous project were not matched up at all. Everything appeared to be zoomed in and messed up. I fixed the issue by going to the “Select Playback Resolution” and switching from 1/2 to “Full.” Not sure why the update did that.
  • Matt Dunne
    June 22, 2016 at 4:33 pm
    Welp, I feel like a dope. My sequence settings were crazy and it wasn’t outputting the right signal.
    Thanks for the lightbulb/face palm moment. Time for more coffee.
  • Oliver Peters
    June 22, 2016 at 5:16 pm
    [Chris Paul] “RE: it works with Blackmagic sequences but not with some source formats like Sony XAVC”
    Not surprising, however, at this end all is fine. I usually create ProRes-based settings. In some cases, you might want to reinstall the BMD software. Occasionally it wants to be the last thing installed after some of these updates.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • Oliver Peters
    June 22, 2016 at 5:18 pm
    [Jason Warfe] “My save file was completely messed up after the update.”
    Mine seem OK, although some of my LUT settings in Lumetri are messed up. Even after pointing to the correct LUT, some apply and some don’t. So I had to re-correct a number of shots in my timeline.
    – Oliver
    Orlando, FL
  • Peter Corbett
    June 22, 2016 at 9:29 pm
    Pretty good here but all my Lumetri presets and custom ones were mixed up or gone. I’ve only opened one project but had to manually reload nearly every clip with the correct LUT. Premiere 2015.3 has reassigned most of the clips with the Phantom LUT.
    Peter Corbett
    Powerhouse Productions
    http://www.php.com.au
  • Duke Sweden
    June 23, 2016 at 12:01 am
    I got an email from Red Giant stating that their plugins are compatible with a free update. FYI.
  • James Brady
    June 27, 2016 at 5:11 pm
    Updated last week and am having two major issues:
    1) Adobe Premiere Pro loads all Genarts Sapphire effects plug-ins on the launch screen, but they are not available under the effects tab. It’s like Premiere simply cant find them anywhere (After Effects finds them just fine).
    2) Also in Adobe Premiere: If I apply Ultra Key to a clip and attempt to adjust the “Contrast” slider, the program monitor and all external video output goes black. Video playback is lost until Premiere is restarted… and lost again if the playhead touches the clip with the Ultra Key plugin.
    James Brady
    Senior Editor
    Results Video, Inc.
    El Paso, Texas
    http://www.resultsvideo.com
  • Steve Brame
    July 13, 2016 at 1:38 pm
    Same here with Ultra Key – I don’t even have to adjust the “Contrast” slider. Within a few seconds of opening the project, all playback screens with a clip showing in them go black – even the bin thumbnail players!
    Asus P6X58D Premium
    Core i7 950
    24GB RAM
    nVidia GeForce GTX 770 – 361.75
    Windows 7 Premium 64bit
    System Drive(OS, Projects) – WD Caviar Black 500GB
    2nd Drive(Pagefile, Media Cache) – SSD 150GB
    Media Drive(Media Files, Previews) – 2TB RAID0 (4 – WD Caviar Black 500GB drive)
    Matrox MX02 Mini
    Adobe CC (Premiere 2015.3)
    QuickTime 7.7.5
  • James Brady
    July 13, 2016 at 2:35 pm
    Three weeks into testing Adobe Premiere Pro CC 2015.3 has revealed numerous issues–some are quite literally show-stoppers. Adobe’s Premiere forum is buzzing with similar reports. My advice for anyone employing Premiere in a business environment is to continue using 2015.2 until the next patch/release from Adobe. They’ve been good to us for a long time …they’ll fix it!
    James Brady
    Senior Editor
    Results Video, Inc.
    El Paso, Texas
    resultsvideo.com
  • Oliver Peters
    July 13, 2016 at 2:36 pm
    Such as?
    Oliver
    Orlando, FL
Page 2 of 3
