a couple of simple questions about Sennheiser ME66
Ty Ford replied 17 years, 1 month ago 4 Members · 16 Replies
David Payne
August 12, 2009 at 7:56 pmthanks guys I will take the battery out when I’m not using it, and keep an eye out for a DXA-4 or even better DXA-6 on the cheap…
Is there any other cheaper way I could split the shotgun and wireless mic into the left and right channels so that I can mix them together if I choose to do so in post? I was hoping to 2 to 1 XLR cable would do the job but as I said I was disappointed to find it mixes the tracks together before it gets to the camera…
Ty Ford
August 12, 2009 at 8:17 pmsure.
https://www.trewaudio.com/store/product.php?productid=147&cat=21&page=1
Regards,
Ty Ford
Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
Watch Ty play guitarSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
David Payne
August 13, 2009 at 8:18 amTy,
thanks a lot for that. Thats what I THOUGHT I was buying when I bought the $15 lead that I have… but obviously thats why it was so cheap?
I just need to find one in the UK now and try to confirm with the vendor that it will do left and right channels and not merge. I think that will do me for now while I get used to using the sennheiser wireless. Once I’m used to that and find that I use it a lot, I will consider a DXA-6. -
Ty Ford
August 13, 2009 at 12:22 pmDavid,
If you have two mic level sources with XLRs that need to input a 1/8″ stereo input without combining, that IS the cable you need.
It’s a custom cable that Trew makes. They also make one that feeds a mono source to both stereo inputs so you can have one mic feeding both tracks equally.
Regards,
Ty
Watch Ty play guitar -
David Payne
August 13, 2009 at 3:29 pmgreat thanks Ty I’m going to get one. I think the cable I must have at home is the one that combines the mono signals.
Hopefully I can find the cable in the UK, if not I will consider a purchase from that site. Of course if I can get a beacktek for slightly more then I will.
I’ve certainly learned a lot in this thread, thanks to all.
Ty Ford
August 13, 2009 at 3:41 pmDavid,
If you’re considering a mixer, please look very hard at a Sound Devices 302. Much better all around than any beachtek
Regards,
Ty Ford
